Kolbi
I just installed vBActivity Lite on my localhost and by visiting a thread I get this issue:
Warnung: Division by zero in [path]\dbtech\vbactivity\includes\libs\activity.php (Zeile 296)
Yeah, I see the problem. You can fix it by manually recalculating points - AdminCP -> vBActivity -> Maintenance -> Recalculate Points.
This will be permanently fixed in the next version.
If I try to post:
Die Cookies konnten nicht gesetzt werden, da der Header schon an den Browser geschickt wurde.
Datei: C:\Xampp\xampp\htdocs\includes\class_core.php
Zeile: 4482
Okay thank you after using maintenance the issues are away.
I´m currently translation it into German.
I guess I´ll translate vBShout, too.
Cool, glad that it helped :D
I have updated the files both here and on vBulletin.org so that this should no longer happen for new users. Thanks for reporting it :D
There are some remnants of a previous incarnation of the Awards systems in the phrases, yeah.
But you don't need to worry about them, if you don't see them in the vBOptions, they aren't included :)
Legacy vBActivity & Awards
