Question How do I include all the vbactivity (past, present and future) w/o using vbactivity
s3ponline
Was wondering how I can go about incorporate the points for like/thank/reputation (basically everything used to calculate activity) w/o using vbactivity.
I don’t want to use vbactivity because recalculate vbactivity points reups everyone’s credits.
Darkwaltz4 your assistance is needed. Thank you :)
For that vbcredits needs to be integrated with those actions, which unfortunately it is not yet.
You could leverage vbactivity into doing a one-time calculation for you, but the process might be a little complicated. Start with a non-vbactivity currency in vbcredits. Once you are happy with the settings for the supported actions, use vba to recalculate from 0 using only the thanks stuff (honestly im not even sure if you could do that). then, you can do a transfer from vba to vbc without importing vba as a new currency, to supplement your vbc amounts with the lacking thanks stuff.
let me know if you wanna give that a try and if you need help with it.
Ok. In theory, wouldn’t that only account for everything in the past and not future activity?
exactly. thats why i said one-time. assuming you only fill out thanks stuff with vba and recalculate regularly, you could do this manually for awhile i guess.
Whew, there should definitely be integration or a better way of gathering all the activity and using it as points.
Hmm, that puts a wrench in things. Is there a list somewhere that lays out everything that vbCredits can calculate as points?
Legacy vBCredits II Deluxe
