Question updated / reverte navbar template or some section ofvbulleting 418 may not function
terc
Hi, Ozzy47
It looks like there is something wrong at AdminCP; a message shows the followeing
"The templates shown on this page have been updated in the default template set since you customized them.
It may be necessary for you to revert the custom templates, or otherwise check that they fully support vBulletin 4.1.8. If you do not do this, some sections of vBulletin may not function! Please see the release announcements at the vBulletin.com Forums for more information."
Could you plaase check it out
Thanks
kevin
OK you should be looking at a screen like this:
If you have a tick box like the red arrow is pointing to, you can tick that box, and then click on Dismiss Selected Nitifications.
If not you can revert the template, like the black arrow is pointing to, that will open up a new screen, then you can click on Yes. You should save a copy of the template to insure the revert does not break anything.
Then you may have to apply the edit for the second navbar after reverting.
Legacy vBNavTabs
