beforum
My forum got screwed up this morning. I had VBSEO installed and I had been meaning to install dbseo, hadn't gotten around to doing it. It looks like the best alternative.
I had to manually remove vbseo from my site as I was getting errors everywhere and finally I could then log into the backend. I also copied over the original .htaccess over.
I have now installed dbseo following the instructions and the installation was fine. The problem is when I enable the mod, I get 404s for all of the links. I guess it is related to the .htaccess file but not sure what.
Here is a copy of the file:
RewriteEngine on
# RewriteBase /forum/
# Options -MultiViews
RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -l [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^.*$ - [NC,L]
# Forum
RewriteRule ^threads/.* showthread.php [QSA]
RewriteRule ^forums/.* forumdisplay.php [QSA]
RewriteRule ^members/.* member.php [QSA]
RewriteRule ^blogs/.* blog.php [QSA]
RewriteRule ^entries/.* entry.php [QSA]
# MVC
RewriteRule ^(?:(.*?)(?:/|$))(.*|$)$ $1.php?r=$2 [QSA]
# Check MVC result
RewriteRule ^(.*)$ - [NC,L]
RewriteRule ^(.*)$ - [R=404,L]
RewriteEngine On
RewriteCond %{REQUEST_URI} !(admincp/|dbseocp/|modcp/|cron|mobiquo|forumrunner|api\.php)
RewriteCond %{REQUEST_FILENAME} !/(admincp|dbseocp|modcp|clientscript|cpstyles|images)/
I removed everything else from the .htaccess and now it is working. Have some other issues but will open a new thread.
