ski-whiz
I have quite a few mods from here. Paid and lite versions.
Currently I have vbshop, credits II, Thanks, and I think some more.
I have built the android app, and have it published in their market. However when I use it to browse my site/threads, I can only enter some threads. The rest of the threads bring up a server error issue window. vBulletin says to check your installed products.
I disable the whole hook system and the android (mobile) app works pretty good. I'm able to enter a thread in which I wasn't with the products enabled.
So I started to disable the products one by one. The end result was that I had to have ALL my dragon-byte products disabled in order for the app to load threads.
I used the same thread each time, and I could pin point down that it is indeed the DT mods.
they post a little troubleshooting guide here on vb.com:
http://www.vbulletin.com/forum/showt...shooting-guide.
That page tells you how to bypass the mod for their mobile suite. I jsut don't know where their fix goes.
I'm sure this will be huge in the coming months/year...
Right now I have to disable all your mods because frankly the mobile apps are a bigger draw to my site than the bells and whistles..
Please help me out..
thanks!
Rick
Open every single plugin in the plugin manager and wrap each of the require(); calls in the bypass code found in your link :)
The only problem is the vast amount of time it takes (as I'm sure you've felt on a personal level right now xD).
We'll set up DBTech with the Mobile Suite and find workarounds that way :)
