Bug Error after installing Pro 2.4.0 - Wrong Datatype?
subaruclub
I just installed the pro version of VBOptimize.
I am using FileCache as the method of caching.
I believe I have set all the parameters correctly.
However when I enable and view my site I get the following errors above the header of my site:
Warning: in_array() [function.in-array]: Wrong datatype for second argument in [path]/dbtech/vboptimise/includes/cachers/cacher_templates.php on line 17
Warning: in_array() [function.in-array]: Wrong datatype for second argument in [path]/dbtech/vboptimise/includes/cachers/cacher_templates.php on line 22
Warning: Invalid argument supplied for foreach() in [path]/dbtech/vboptimise/includes/cachers/cacher_templates.php on line 115
Also, provided we can get this issue fixed. Do you offer a service to setup and configure a better caching method (like Xcache) for a customer? I asked my hosting company several times to enable XCache. They tell me it is fully configured and setup properly. However your software does not detect it and will not let me choose it as an option.
Thanks,
D.
Hmm, I can't replicate this issue on my test board. Could you please PM me with an FTP account as well as an AdminCP account? If so, I should be able to look into it.
Regarding XCache, the following two scripts will let you test whether XCache is indeed installed and working:
<?php
xcache_set('test', 'Working!');
<?php
echo xcache_get('test');
Run the first script, then the second. If the second does not print Working! then XCache is not configured correctly.
