Does it happen on all browsers or only the one you reported?
That's really strange, when you hover over the General Settings in that menu, what shows up as the link, in the bottom left corner? You can c/p it here by right clicking on it.
http://www.allyouneednascar.com/admincp/options.php?do=optionsdogroup=dbtech_custom_nav_general
http://www.allyouneednascar.com/admincp/options.php?do=options&dogroup=dbtech_custom_nav_general
For some reason, it is not putting the & in the link, I don't know why, cause it should be, it should look like this:
Code:http://www.allyouneednascar.com/admincp/options.php?do=options&dogroup=dbtech_custom_nav_general
Maybe redownload the zip, and upload, includes/xml/cpnav_dbtech_custnav then clear your cookies and cache then try it again.
