In that case, you may have a conflicting plugin somewhere. Please try disabling all other modifications, leaving only Forum Ads active.
If this resolves the issue, re-enable them one-by-one until you find the culprit.
I disabled all plugins but Forum Ads (even vB Blog and vB CMS). To be sure I did all possible vB Repais and Maintenance and Forums Ads Repais and Maintenance, but still same result.
(Also rebuild threads/forums/etc/etc)
Please be aware that I am currently preparing to travel, so it may take 1-3 days before I am able to investigate this on your site.
Update: Hey, sorry for the massive delay :(
I've fixed it on your site, it was a complex fix that required me to almost completely rewrite the way the postbit integration works, but it works on your site now :)
I'll release Patch Level 1 to seed these fixes to the rest of the community tomorrow, you won't need to install it though.
Legacy DragonByte Forum Ads
