EasyEasy
Hi
Updated my current version to 3.0.1 today and when adding a forum block and selecting Post/Thanks/Like I get the following error with what looks like half a page of settings for the forum block
Fatal error: Class 'vB' not found in *******/includes/block/dbtech_thanks.php on line 99
thanks
I've uploaded a potential fix for this, can you re-download and re-upload the files and see if that helps?
HI Fillip H.
Uploaded the files and now get the following error in the same place when adding the block
Fatal error: Using $this when not in object context in *********************/includes/block/dbtech_thanks.php on line 92
Also get a blank page when visiting a notification alert of thanks/like/dislike its from this link
http://*********.**.uk/forumsthanks.php?do=profilenotif
Re-download and re-upload that file again + /dbtech/thanks/hooks/notifications_list.php and it should be fixed :)
There's no need to mention me in threads belonging to "my" forums, it won't get your post noticed any faster :)
The block will only show when there's data to display, are you sure this exists?
Im not looking for my post to be noticed any faster by putting the mention in.
Ive tested a few likes after I installed the files about but nothing is coming through on the forum sideblock
Could you please PM me with an FTP account and an AdminCP account? If so, I'll look into it and see if I can figure out what's going on :)
The issue was caused by two things:
1. I had accidentally flagged the sideblock template as Pro-only in my developer tools
2. A change in the way template conditionals are parsed in your version of vBulletin.
I have fixed it on your site and added the fix to the release package for both Lite and Pro.
Thanks for your help in tracking this down, couldn't have done it without you :D
I cant thank you and the rest of the DBTech staff enough. Although im not a regular poster on here the mods you supply to my are site make it what it is.
Keep up the excellent work and thanks again
