Mommaoz
I'm 99% sure it's user error but I need help -
I downloaded DBTech Advance Post Thanks/Like from vbulletin.org
I *thought* I uploaded everything to the correct directories....
I see the options for the mod and enabled the buttons via admincp
I see the buttons... but when I click them, nothing happens.
Any thoughts on a common mistake I may have made or thoughts on what I should check?
I've currently disabled the mod because my users here are ancy and want everything to work right this second and I don't want to be flooded with questions while I figure it out....
THANKS in advance.
I cannot look at your forum to test it because your forum pages produce a 500 Internal Server Error. Let me know once you've corrected that and then I'll take a look :)
yes - I buggered something earlier... but it SHOULD be fixed now... should I enable the plugin? or will that matter?
