Bug Nothing happens when i click like button
SwitCh
I have a problem ive installed this mod at first it didnt work then i repaired cache then i was able to edit the buttons but my problem is the buttons are showing but when i click on it nothing happens.
Ive searched this whole forum but i couldnt find a solution i also have when i mark can click and usergroups when i save it and go back to edit all usergroups are unmarked i hope someone can help me with this
Thx in advance
Hi there,
Your site is actually listed on our piracy tracker as having an illegal version of vBShout Pro - we checked manually and there are indeed unlicensed Pro files for these products on your server.
For obvious reasons we are unable to support people using illegal versions of our software, please purchase licenses for these products to use them legally.
Regards,
Hi there,
Regards,
Ok so if i delete this pro version will i be able to get support again?
the same happens to a site im partners with could you see if this is also the case we are using vb 4.2.4pl3
error console
{ftd.on('click','a[name=dbtech_thanks_downranked]',function(e)
the popup says *uncaught typeerror: ftd.on is not a function*
error console
Please start a new thread for the issue as this one has already been assigned "not an issue" status and won't be seen by support.
Hello SwitCh,
