Trekkan
When you enable TT, it shows in the navbar, even if you don't have access to use it.
After installing (or in the doc file), there's nothing to tell you that you have to enter each usergroup to give it access to TT.
Needs a disable for the Navbar plugin.
There is no starter deck defined by default. Not a big deal, but necessary. Since you can set the cost to 0, that works out so that people can always purchase a starter deck. But leaves this open to exploitation as well. Would be better if there was a way to set everyone's "Gil" to a specific amount.
*edit* This is a better issue than I thought actually.. setting it to 0 let's someone just buy the "starter" deck I made over and over again, getting all the cards they want for free.
Possibly would do a retro-active scan of posts, but really.. that'd give out way too much to begin with.
Hmm, no default anything. Would be good to have what you guys use here as a baseline to start. There will be plenty of people like myself who really don't know the rules and how things should best be setup. This will allow for exploitation in the beginning if the settles aren't right.
