Fakher
I did upload all the files and perform an xml import. It was clean. No error or warnings but i ca't see vbshop anywhere? Not in adminCP not even footer link?
Now what to do?
Regards
Fakher
In My config.php
$config['SpecialUsers']['superadministrators'] = '1';
Where 1 is UserID. If so then I am already a Super Admin.... what else?
Lolzz this is strange .... Before installling vBShop I installed Statuses and Moods addon. After that i tried with vBshop but it did never work.
Now what i did :)
I uninstalled vBStatus and Moods addon and straight away i was able to see settings for vBShop :O
no i have installed statuses mod as well. So everything is working fine.
But does it mean these mods are fighting with each other?
I really have no idea why install order would matter, that's really weird... Ah well, glad you worked it out :)
I am getting this email after every 4-5 hours about vBShop
Invalid SQL:
SELECT
post.userid,
user.dbtech_vbshop_purchase
FROM post AS post
LEFT JOIN user AS user ON(user.userid = post.userid)
WHERE post.postid IN (04790,4790,4791,4824,5464,6794,6916,6927);
MySQL Error : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '
post.userid,
FROM post AS post
LEFT J' at line 2
Error Number : 1064
Request Date : Saturday, August 25th 2012 @ 05:34:34 AM
Error Date : Saturday, August 25th 2012 @ 05:34:34 AM
Script : http://hostingdreams.net/forums/showthread.php?832-Avatar-(2009-film)&p=6927
Referrer :
IP Address : 212.113.37.105
Username : Unregistered
Classname : vB_Database
MySQL Version :
You can re-download and re-upload /dbtech/vbshop/hooks/showthread_query.php and it will be fixed :)
Re-intalled it, now back to previous problem :( All imported but no settings :(
Update : This is strange I unistalled Moods and status and vBShop settings were back then I was able to reinstall Moods and statuses as well.... This is confusing :(
Nway Can I use vBActiviy points here if so what "Points Column" setting should be?
So thst vBShop can pick up Activity Points?
dbtech_vbactivity_points is the points column name. The points table is still user :)
Now what is wrong with my vBShop ? Its broken ....
HD Community :(
I don't want to reintall it as I ll have to add all items and Lotteries again from scratch :(
So how can i fix this
Legacy vBShop
