Sweet! Thanks a lot guys!I fixed it on your site; there was a block of code that was preventing the slider from displaying on the CMS.
Can you try the attached file? It goes in /dbtech/vbslider/actions/ . Overwrite the original file. The garbage is the image file it is trying to retrieve. Oh, just thought of something... Can you see if the following folder exists? /dbtech/vbslider/images/externalimages . Also, make sure the permissions are set to 755.
Hmm... send me a link to your site and I'll take a look. Did you notice if there were any files in the externalimages folder? Just trying to see if its completely failing or not...
Warning: fopen([path]/dbtech/vbslider/images/externalimages/thread-257.com/images?q=tbn:ANd9GcSoBBklm03ByauJJSivUPQVWGmCnYC7CtJC-8tx8r-7cgpHQPLG&t=1) [function.fopen]: failed to open stream: No such file or directory in [path]/dbtech/vbslider/actions/widget.php on line 433
Warning: curl_setopt(): supplied argument is not a valid File-Handle resource in [path]/dbtech/vbslider/actions/widget.php on line 437
