IcEWoLF
Warning: explode() expects parameter 2 to be string, array given in [path]/dbtech/vbdonate/hooks/process_templates_complete.php on line 33
Warning: explode() expects parameter 2 to be string, array given in [path]/dbtech/vbdonate/hooks/process_templates_complete.php on line 117
Warning: explode() expects parameter 2 to be string, array given in [path]/dbtech/vbdonate/hooks/process_templates_complete.php on line 261
Warning: explode() expects parameter 2 to be string, array given in [path]/dbtech/vbdonate/hooks/process_templates_complete.php on line 266
Warning: explode() expects parameter 2 to be string, array given in [path]/dbtech/vbdonate/hooks/process_templates_complete.php on line 270
Warning: explode() expects parameter 2 to be string, array given in [path]/dbtech/vbdonate/hooks/process_templates_complete.php on line 279
Not sure what's going on. :/
hmmm re download and upload the file, dbtech/vbdonate/hooks/process_templates_complete.php
Ozzy, that fixed the errors, however the sideblock is missing couple things, any way to fix this?
I deleted the old sideblock module as instructed then added the new one.
Also when trying to view user profiles I get the following error:
Fatal error: Call to a member function query_read() on a non-object in /home/rsquadco/public_html/dbtech/vbdonate_pro/hooks/postbit_display_complete.php on line 18
Re download and delete the module, and upload the new one. For the other error,
Also one more thing I wanted to report, I got this error when upgrading to the new version (styles error)
That is due to the templates being edited and not being overwritten, perfectly expected behavior.
OK the Fatal error: Call to a member function query_read() on a non-object in /home/rsquadco/public_html/dbtech/vbdonate_pro/hooks/postbit_display_complete.php on line 18 has been corrected as well, not entirely sure why that happened, as that line was the same in this version and the last. :confused:
The paypal image is clickable, but the image is added now, and clickable also, it is in the sideblock settings you can change the image there.
On a previous version somehow you made it non clickable and looking like this:
I can't remember how we achieved this :/
That was some template editing, as you can see now, the image is inserted if you choose the option to insert it, it is just in a different location.
The bottom placement doesn't make any sense, the paypal then the vBdonate would be better, trying to get this fixed but somehow keeps messing up and I keep editing.
:p
Legacy vBDonate
