bosss
Hello
On my test site I get double user info in postbit. Some solutions?
Will attach picture!
Also in my product info shows ver. 1.1.0 b1 and in client area latest version is 1.0.5 which I install for some hours ago! Mmaybe I downloaded wrong version?
regards
bosss
Sorry, the forums seem to have eaten my response.
You'll need to edit the user info out of the postbit_legacy template.
Change the relevant part of the template to this:
			<vb:if condition="$post['userid']">
				<hr />
				<dl class="userinfo_extra">
					{vb:raw template_hook.postbit_userinfo_right_after_posts}
				</dl>
				{vb:raw template_hook.postbit_userinfo_right}
				<div class="imlinks">
					{vb:raw post.icqicon} {vb:raw post.aimicon} {vb:raw post.msnicon} {vb:raw post.yahooicon} {vb:raw post.skypeicon}
				</div>
			</vb:if>
Thanks - I do that and no is not double ...but still have one small issue - can not get reputation info in postbit tabs ...I enabled in admincp - options ..in my profile settings ..made rep. info active and put them in user info#1 tab ...but nothing shows ... (mean reputation power text in postbit)
some help?
regards
bosss
You can use this code in a new View for reputation info:
<vb:if condition="$show['infraction'] OR $show['reppower']">
<dl class="user_rep">
	<vb:if condition="$show['infraction']">
	<dt>{vb:rawphrase infractions}</dt>
	<dd>{vb:raw post.warnings}/{vb:raw post.infractions} ({vb:raw post.ipoints})</dd>
	</vb:if>
	<vb:if condition="$show['reputation']">
		<vb:if condition="$show['reppower']">
	<dt>{vb:rawphrase reppower}</dt>
	<dd id="reppower_{vb:raw post.postid}_{vb:raw post.userid}">{vb:raw post.reppower}</dd>
		</vb:if>
	</vb:if>
</dl>
</vb:if>
Have you used the UserCP options for this mod to re-order your tabs / views for your user? If so, you may need to update this newly created view there as well.
I did not made any changes in usercp - settings for postbit tabs ... I saved changes (what was default) ... and refresh again and no result in postbit.
regards
bosss
Is there a reason why your site randomly takes 30+ seconds to load a page or fails to load with a timeout error? It makes it a lot harder to debug this issue when I have to sit and wait for a very long time for each page to load.
Update: The FTP now fails to load any directories and the front-end has been loading for over a minute without completing. I will have to give up attempting to look into this this until your server has been fixed.
Let me know when you have fixed these issues so I can proceed.
No, had not that problems before.
regards
bosss
edit: Just check and loads fine both (test and main).
It seems like I can access the site correctly now. I've solved the issue on your test site by slightly altering the "reputation" view.
Do not understand - what I must do if decide to install on main site? " altering the "reputation" view? Please explain more.
Thanks for help and Your time.
regards
bosss
This is the contents of the "Reputation Info" that is working on your test site:
<vb:if condition="$show['infraction'] OR $show['reputation']">
	</vb:if>
	<dd id="reppower_{vb:raw post.postid}_{vb:raw post.userid}">{vb:raw post.reputation}</dd>
	</vb:if>
</dl>
</vb:if>
If it doesn't work on your live site, try replacing the HTML code of the view with that code.
Legacy Postbit Tabs
