motd2
After upgrading from 1.0.5 - not displayed in postbit.
After removal of the 1.0.5 and a new installation 1.1.0 - not displayed in postbit.
re-activate Postbit Tabs and edit/save - not displayed in postbit.
Sorry, I don't understand your question. What is not displayed in the postbit? Have you created a View with some content in it? Have you ensured it's active, and that the usergroup settings in the View or the Tab isn't blocking you from viewing it?
v1.0.5
After upgrading - nothing
New install 1.1.0 - nothing
New install 1.0.5 - ok
active, usergroup settings not blocking
Turn off
first DragonByte Tech: vBShop (Pro)
second DragonByte Tech: User Status & Moods
third DragonByte Tech: Postbit Tabs (Pro)
after DragonByte Tech: vBActivity & Awards (Pro) - Postbit Tabs worked!
So are you saying Postbit Tabs only works for you after turning off those 4 mods?
I'll need those access details in order to debug this issue further.
after turning off those 4 mods - Postbit Tabs works
after turning on those 4 mods - Postbit Tabs works
probably something with the cache :confused:
Legacy Postbit Tabs
