megatr0n
If you are having problems with vBulletin AJAX functions hanging seemingly with no end, please disable the "AJAX Handler" plugin in User Status & Moods.
This plugin is defunct and no longer used.
The XML file has been updated to remove this plugin.
What, do you mean defunct?
If we disable that option does that mean the hack will not update in real time?
"This plugin is defunct and no longer used." meaning the AJAX functionality has been moved to its own file in order to ensure vBSEO doesn't unneededly cause lag.
After installing this update my forum has like a list of the updates showing at the bottom of the index page. There is no option to hide or remove this, how do you remove it?
The new version is not working properly. The pictures speak ..
I'm sorry, my English is bad (the 1.3.5 version does not have this problem)
Please ensure that the chosen category contains any moods, the Mood Manager will tell you.
It's not stupid - it's intended to work without a category :) A fix will be uploaded within a week I'd say, I'm majorly busy these days.
Please post any issues in a support thread, this is a release thread :)
I'll split it from the release thread and lock it.
Legacy User Status & Moods
