Adam H
When you see a notification popup you click it and it redirects to the forum home ( as if its been treated as a 404 error ) , if i disable vbseo then it works perfectly. I do not rewrite user profile URL's however ?
Any idea's ? i was using the lite version of this mod with no problems, just purchased the premium version and this problem is instant.
I use vBSEO's own functions for generating the profile URL, interestingly their own code returns broken links...
I'll have a more permanent fix for this in the future.
Whats the temp fix for this then ? the mod is pretty useless for me with out it working correctly.
Surely if the lite version has worked perfectly fine for the past 6 months the paid version should also work ? If it doesnt then who do i see about a refund because the product is useless to me if its not working correctly.
It was a recent change that was implemented to both Lite and Pro.
You can revert it by changing the notifications_list.php plugins for Lite and Pro (usertag and usertag_pro folders respectively and remove the bits that start with
        if ($vbulletin->products['crawlability_vbseo'] AND file_exists(DIR . '/vbseo/includes/functions_vbseo_url.php'))
So that only the bit that starts with
$link = (intval($vbulletin->versionnumber) == 3 ? 'member.php?'
remains.
That worked perfectly thank you, although for anyone else with problem remember to also delete the closing brackets on lines : 35 , 48 , 58 other wise it will give you an error.
Legacy Advanced User Tagging
