Website
http://www.divided-allegiance.com/vbulletin/forum.php
Forum version
vBulletin 4.2.x
#1
I added the twitch.php Url for the tab. I added the permissions for each group. I had no issues. The issue is though I can't get the Nav bar to work, in the Read me says to use twitch.php. I tried that, among other things with no luck. I can't use this at all at the moment. Any help would be great.
Belazor
Staff member
Owner
Developer
Can you please provide more information? I need to know what's not working for you, what error message you're receiving, what exactly you're doing that's not working, etc.
#4
No error message
It doesn't show up... I think the issues may be URL related, it can't find it. I used twitch.php... I get the 404 error when I added the twitch to my Nav manager in the ACP Options.
I gave the group permissions, checked both Yes. I also made a channel in the Channel settings.. They all works fine. So again I believe it is a incorrect URL to mod , which I can't find the correct URL, the read me said twitch.php. I have added many mods for a Nav bar manager before, I have 4.2.0 CMS.. Never had one fail, so unsure why this one is.
if you need any more information let me know... I linked my site and did a test bar and left it up, you will see the error. when you select that tab.
Belazor
Staff member
Owner
Developer
If you're receiving a 404 error when going to /vbulletin/twitch.php on your site, then this indicates the files have not been uploaded correctly.
Please drag and drop the contents of the upload folder (not the folder itself) into your vbulletin folder.
#7
I re-Installed everything, it worked. No clue why it didn't take but I think it was the PHP file it missed, I believe that was the same issue before. I had a friend help me last time, and I remember I normally install one by one in the UpLoad. He said do them all at once, I forget he told me this and remember to try it again, I did and it worked..
Live Streaming Suite
