Question Import from Abe1 and make it work with vBexperience
MonkY
Hello!
How can i import Thanks from Abe1's Post Thank you Hack?
Also does this works with vBExperience? Will it generate points like Abe1's hack does? Does it substract points for dislikes? :)
Thanks in advance!
Importing is a Pro-only feature :)
I have no idea if it works with vBExperience, you should ask in the vBExperience forum :)
Hello!
Thanks in advance!
Because of the way VBE works (e.g it doesn't store data in a way that allows for spending for instance) a lot of mods don't work with it - I recommend giving our vBActivity and Awards system a try, many of our customers switched over from vBE to vBAA and say it is much better.
I agree I used vBExperience way back, once vBActivity & Awards was out I snagged it up.
