cykelmyggen
After uploading the vBshout version 5.4.8 my forum as well as my ACP is not accessible. The message shown on both forum and ACP page is: Fatal error: Class 'VBSHOUT' not found in /var/www/sites/boggnasker.dk/vbforum/dbtech/vbshout_pro/hooks/process_templates_complete.php on line 9.
PS I can still access the CMS-driven Frontpage.
Add
to your config.php then re-upload the files and re-import the XML.
Open your config.php and below<?php add this line, define('DISABLE_HOOKS', true);
So it looks like this:
<?php
|| # vBulletin 4.1.4
Then make sure all files are loaded to the proper place, and re import the xml, then remove the define('DISABLE_HOOKS', true); ftom the config.php
