angeljs
I know this isn't your mod's fault, but I've tried posting in the mod developer's forums, but the support is terrible. I'm using vBadvanced Dynamics for my downloads section, but when your mod is active, I get the following error message when I try to use the advanced reply instead of the quick reply:
This is the line of code:
I was just wondering if it would be possible for some help with this, even though it's not your fault another mod is causing this clash.
Fatal error: Cannot use object of type mysqli_result as array in /home/******/public_html/sims/downloads/newreply.php on line 798
SELECT pagetext, username, dateline " . iif($query['getsmilie'], ', allowsmilie') . "
