Taurus
Just over a month ago my forum was severely hacked. Now after a month it is still a mess. My hosting company has tried to get it back, and the only way we got it half working is with a database of more than a year ago. However I can still not login to my ACP. I don't know if anyone here can help me with this, but I really really hope so. This whole experience has just been horrible.
Apparently when I try to login it renders the following database error: (This from my hosting company)
I am getting the error message as follows while login to the the link Log in - Windows 7 Themes - CreativX - vBulletin Admin Control Panel
Database error in vBulletin 4.2.0:
Invalid SQL:
SELECT bbcodeid, bbcodetag, twoparams, title, buttonimage, dbtech_vbeditortabs_id FROM vbbbcode;
MySQL Error : Unknown column 'dbtech_vbeditortabs_id' in 'field list'
Error Number : 1054
Request Date : Tuesday, May 7th 2013 @ 05:20:12 AM
Error Date : Tuesday, May 7th 2013 @ 05:20:12 AM
Script : http://creativx.net/forums/login.php?do=login
Referrer :
IP Address : 111.92.64.16
Username : Unregistered
Classname : vB_Database
MySQL Version :
Stack Trace:
#0 vB_Database->halt() called in [path]/includes/class_core.php on line 426
#1 vB_Database->execute_query() called in [path]/includes/class_core.php on line 459
#2 vB_Database->query_read() called in [path]/dbtech/vbeditortabs/actions/tabs.php on line 31
#3 require_once([path]/dbtech/vbeditortabs/actions/tabs.php) called in [path]/dbtech/vbeditortabs/hooks/global_start.php on line 95
#4 require_once([path]/dbtech/vbeditortabs/hooks/global_start.php) called in [path]/global.php(29) : eval()'d code on line 256
#5 eval() called in [path]/global.php on line 29
#6 require_once([path]/global.php) called in [path]/login.php on line 41
This error message shows that 'dbtech_vbeditortabs_id field is missing in the table vbbbcode.
Please contact your developer to correct your mysql code correctly.
I have no idea how to fix this.
Thank you so much!
Invalid SQL:
Error Number : 1054
Referrer :
MySQL Version :
Stack Trace:
Thank you so much!
