Webbstre
Hi there! So fun backstory to start with. I'm moving my site over to a new nginx setup. I've managed to configure everything and get it working smoothly, save for one detail. Whenever vbOptimise Pro is on and I go into admincp and try to save an advertisement or notice I get a white screen. It only happens with this modification enabled. I'm not sure if this is an nginx thing or something with my xcache settings, but I have found one more oddity. I can't seem to flush the cache from with vbO, either through the Flush Cache option or via the System Test. I'm guessing these are possibly tied together. Any suggestions?
If you need to access the site, it's not live yet, so I'll have to send you the hosts file info to access the new server. Once I get this fixed I can switch over with zero downtime ;)
Can you try setting it to Filecache and see if the problem still occurs? If so, then it would indicate a problem with your XCache settings :)
Yup, switching it to filecache gets rid of the whitescreen. I was reading some other threads and think I know the problem now: xcache doesn't appear to accept my local php-ini setting to turn authorization off, so I'll have to file a support request. I suspect I'll be able to flush the cache and all that once I get this setting fixed. Thanks for the fast response though! I'll update you when it's over.
