We are running Apache/2.2.14 (Ubuntu) PHP Version 5.3.2-1ubuntu4.14.1 MySQL 5.1.61, XCache 1.3.0
vB 4.2.0 p2 and vBOptimize 2.4.0.
The site is running great! However, in the admincp, when I try to configure anything I get nothing but a white page. All vBadmin is frozen
My fault: I've setup Xcache instead filecache that was running smothly
All tests load fine except flush and I can't change anything now.
I need to revert hard way: delete files on ftp and reinstall with new settings.
Wich files I should delete to get xcache unabled and revert to filecache?
Add the following to /includes/config.php directly beneath the
tag:
Then swap vBO's config to Filecache :)
Problem solved for the admincp and the filecache setting or even the Xcache setting, so I can chose both.
My problem now is that the vB Optimise: Test Setup does'nt show nothing now. And the statistics are gone now. I suppose this is normal.
When I have more money I'll go for the paid version, one plugin at a time.
Uh no, you need to change it to Filecache, then remove the code from config.php that you added in the previous post.
