Crashys
After install and activate xcache, i activated the cache template and styles...
After that: Warning: xcache_get() [function.xcache-get]: xcache.var_size is either 0 or too small to enable var data caching in [path]/vboptimise/core/class_operator_xcache.php on line 21
Now i can't login to remove that option...
Help?
Just replied to your PM regarding this issue :)
Keep me informed here though so I can assist you.
Forum back up with vbo disabled.
How can i check if xcache is working fine?
I'm trying to improve the forum speed.
The error was XCache wasn't configured with a var size. You'll need to edit your php.ini, look for xcache.var_size, and give it a size, something like 32 would be fine:
xcache.var_size = 32;
Once done, restart apache. Then vBO should be able to use XCache just fine :)
hmm this is my php.ini
# configuration for php Xcache module
extension = xcache.so
[xcache.admin]
xcache.admin.auth = On
# Configure this to use admin pages
; xcache.admin.user = "mOo"
; xcache.admin.pass = md5($your_password)
; xcache.admin.pass = ""
[xcache]
; ini only settings, all the values here is default unless explained
; select low level shm/allocator scheme implemenation
xcache.shm_scheme = "mmap"
; to disable: xcache.size=0
; to enable : xcache.size=64M etc (any size > 0) and your system mmap allows
xcache.size = 16M
; set to cpu count (cat /proc/cpuinfo |grep -c processor)
xcache.count = 1
; just a hash hints, you can always store count(items) > slots
xcache.slots = 8K
; ttl of the cache item, 0=forever
xcache.ttl = 0
; interval of gc scanning expired items, 0=no scan, other values is in seconds
xcache.gc_interval = 0
; same as aboves but for variable cache
xcache.var_size = 32M
xcache.var_count = 1
xcache.var_slots = 8K
; default ttl
xcache.var_ttl = 0
xcache.var_maxttl = 0
xcache.var_gc_interval = 300
check the phpinfo() : http://forum.quadmania.com/info.php
Hm, apparently the xcache extension isn't even loaded. But you have access to the function?
There's also a xcache.ini, perhaps that is overriding your settings, could you post what's inside that? (/etc/php5/apache2/conf.d/xcache.ini)
Fixed! you were right! :)
Can i activate the module now?
