Gumble
This was before updated to the beta version while setting a user to admin level.
Guess it is related to the prefix...
Database error in vBulletin 4.1.0:
Invalid SQL:
UPDATE vb_administrator SET
	### Bitfield: vb_administrator.adminpermissions ###
		adminpermissions = IF(adminpermissions & 4, adminpermissions - 4, adminpermissions),
		adminpermissions = IF(adminpermissions & 8, adminpermissions - 8, adminpermissions),
		adminpermissions = IF(adminpermissions & 16, adminpermissions - 16, adminpermissions),
		adminpermissions = IF(adminpermissions & 32, adminpermissions, adminpermissions + 32),
		adminpermissions = IF(adminpermissions & 64, adminpermissions, adminpermissions + 64),
		adminpermissions = IF(adminpermissions & 128, adminpermissions, adminpermissions + 128),
		adminpermissions = IF(adminpermissions & 256, adminpermissions - 256, adminpermissions),
		adminpermissions = IF(adminpermissions & 512, adminpermissions - 512, adminpermissions),
		adminpermissions = IF(adminpermissions & 1024, adminpermissions - 1024, adminpermissions),
		adminpermissions = IF(adminpermissions & 2048, adminpermissions - 2048, adminpermissions),
		adminpermissions = IF(adminpermissions & 4096, adminpermissions - 4096, adminpermissions),
		adminpermissions = IF(adminpermissions & 8192, adminpermissions - 8192, adminpermissions),
		adminpermissions = IF(adminpermissions & 16384, adminpermissions - 16384, adminpermissions),
		adminpermissions = IF(adminpermissions & 65536, adminpermissions - 65536, adminpermissions),
		adminpermissions = IF(adminpermissions & 131072, adminpermissions - 131072, adminpermissions),
		adminpermissions = IF(adminpermissions & 262144, adminpermissions - 262144, adminpermissions),
		adminpermissions = IF(adminpermissions & 524288, adminpermissions - 524288, adminpermissions),
		adminpermissions = IF(adminpermissions & 1048576, adminpermissions - 1048576, adminpermissions),
		adminpermissions = IF(adminpermissions & 2097152, adminpermissions - 2097152, adminpermissions),
		adminpermissions = IF(adminpermissions & 4194304, adminpermissions - 4194304, adminpermissions),
		adminpermissions = IF(adminpermissions & 8388608, adminpermissions - 8388608, adminpermissions),
	blogpermissions = 0,
	vbcmspermissions = 0,
	### Bitfield: vb_administrator.dbtech_thanksadminperms ###
		dbtech_thanksadminperms = IF(dbtech_thanksadminperms & 1, dbtech_thanksadminperms - 1, dbtech_thanksadminperms),
	cssprefs = '',
	dismissednews = '81,90,91,93,94,95,97,98'
WHERE userid = 264;
MySQL Error   : Unknown column 'dbtech_thanksadminperms' in 'field list'
Error Number  : 1054
Request Date  : Friday, December 3rd 2010 @ 06:36:05 AM
Error Date    : Friday, December 3rd 2010 @ 06:36:05 AM
Script        : http://www.xxx.com/stack/adminpermissions.php?do=update
Referrer      : http://www.xxx.com/stack/adminpermissions.php?do=edit&u=264
IP Address    : xxx
Username      : xxx
Classname     : vB_Database_MySQLi
MySQL Version : 5.0.77-log
After I noticed there was a new version (beta) I get this if I enable the mod:
Fatal error: Class 'THANKS' not found in /var/www/vhosts/xxx.com/httpdocs/dbtech/thanks/hooks/showthread_query.php on line 40
Also my admincp and modcp folders are renamed maybe that can have something to do it too.
Also im running the 4.1.0 PL1
Greetings
Ok its working on 4.1.0 PL1
Just the issue setting the permissions to a admin user keep the problem...
Invalid SQL:
		adminpermissions = IF(adminpermissions & 32, adminpermissions - 32, adminpermissions),
		adminpermissions = IF(adminpermissions & 64, adminpermissions - 64, adminpermissions),
		adminpermissions = IF(adminpermissions & 128, adminpermissions - 128, adminpermissions),
	cssprefs = '',
WHERE userid = 264;
Error Number  : 1054
Request Date  : Friday, December 3rd 2010 @ 12:42:13 PM
Error Date    : Friday, December 3rd 2010 @ 12:42:13 PM
IP Address    : xxx
Username      : xxx
Run this:
ALTER TABLE vb_administrator ADD dbtech_thanksadminperms INT(10) UNSIGNED NOT NULL DEFAULT '0'
