viper357
Hi, just installed the lite version as a try out, couple of quick questions please, I can't seem to find any instructions on how to do all this.
1. In the vbulletin config.php file, I would assume I have to change this to whichever method I am using, is that correct? I'm using filecache at the moment.
2. If I ask my host to install Xcache, do I need to change any settings, I have noticed there is a lot you can do/change in xcache, llike set max users and max connections and amount of ram etc. etc. or do I just do a striaghtforward install and then set vboptimise to use it?
3. Is memcache the preferred one to use? I'm really at a loss as to which one to ask my host to install?
Thanks.
filecache is working great so far and is doing away with a couple of queries already, looking forward to running the pro version, will buy it after xmas shopping is all done, lol.
// ****** DATASTORE CACHE CONFIGURATION *****
// Here you can configure different methods for caching datastore items.
// vB_Datastore_Filecache - to use includes/datastore/datastore_cache.php
// vB_Datastore_APC - to use APC
// vB_Datastore_XCache - to use XCache
// vB_Datastore_Memcached - to use a Memcache server, more configuration below
$config['Datastore']['class'] = 'vB_Datastore_Filecache';
Thanks.
