Force
I click on the attachment in pms upload it then click done but it does not add it to the pm why am i doing something wrong or missing something
Try sending a PM to yourself without doing anything else, you'll see it shows up :)
Alternatively, you can insert it inline via the paperclip.
as you can see on that 2nd ss i dont have inline option. I have sent it to myself and can see it but if i send it to my normal member account i cant
Hey Force.
If you use a .htaccess password protection for your AdminCP directory, it is recommended that you create a new authorized user for DBTech and remove this user once the issue has been solved.
I have the same issue. There is no 'insert inline' function. Thus far I used the paperclip, and that worked. But it would be nice to have the 'insert inline' option also. Thanks.
The inline function is part of the paperclip, if you click on the right side of it, by the arrow, that allows you to insert inline.
Yes, I know that. But on a normal attachment window after you uploaded your files you will have the text "Insert Inline" at the bottom of the attachment window. And you can then select from all the files attached which you want to insert inline while you have the attachment window open. This is now not possible in PM's. Now I have to close the attachment window first, and then insert via the paperclip.
Yeah that is currently not possible.
if i send it inline it shows up as a link like in my above post but to a admin you see the full pic now if it is not inline then normal members cant see any images but admins can
Ahh ok I get what ya mean now, I am able to replicate on my dev, I'll post back when I have a solution.
Sorted, you can redownload the zip, upload dbtech/vbsuper_pm_pro/hooks/pmattach/postbit_display_start.php Then re import the XML.
This will solve two issues, the one you described, that other users could not see the attachments in the PM's. It will also now allow you to see the attachment in the PM if you preview it, before sending. For some reason the plugin never made it in the XML.
Thanks works better one thing after uploading files and clicking ok then do the inline it sends two copies of the file like this
but a normal users sees it like this
Yeah that is expected behavior, but at some point during the next week or so, we will be looking into the attachments, and see if there is a way to make it more like when you make a post.
On a side note, I dunno if that is your test site or not, but in Chrome, the top of the header is cut off, and you can not access the username / password boxes, so you can't log in.
TBH I dunno, it is something you need to investigate. See if it happens on a default skin, with the same logo in the header, if not then it is a skin issue.
works ok for me in chrome must be a addon on your browser causing the problem
Legacy vBSuper PM's
