When DBSEO enabled,
-Post editor is missing all functionality buttons in both quick post and advanced editor/submit thread
-Also uploading of attachments - images upload, but do not insert into post.
How it should be
I have narrowed the issue down to specific plugin within Plugin Manager:
Process Content: Global > require(DIR . '/dbtech/dbseo/hooks/global_complete.php');
Disabling this specific plugin removes the post editor issues..
Once you've resolved the account permissions issue I will look into it and see if I can track it down further. No other forum running this mod has reported this issue, and it's enabled for everyone :)
Update: The problem is your "Crit EYE" BBCode. Since that BBCode doesn't appear to do anything (the window that opens is a blank, HTML-less page), I would suggest you delete this BBCode.
Other issues I came across on your forum: The path to the CometChat CSS / JS was incorrect, and your MySQL Maximum Connections variable appears to be set way too low for your site as I received a few Too Many Connections errors.
