MrBennet
Hey! To start with, sorry for my nondescript title.
I have a few things that I would like to fix with the DBtech - Post thanks mod.
1. In the widget on the right side of: Forum - Tränasmart I would like to display most thanked members. How to do that?
2. The "Post Thanks / Like" when you read a topic, below the username. Can I remove the "Thanks (Given)" ? And can I remove the green arrow to display thanks recieved? I want to show "thanks recieved" by automatic.
3. Can I change the graphic? Look here: Test . I use another theme than the main, therefore the number of post, date of registration, is a bit different. So, is it possible to change?
It´s alot of questions. I hope that someone have any solution. Thank you so much for this! It´s greate!
Best regards
Nils
In v3.0.0 Beta, the widget displays both Recent and Most Clicked within a certain timespan in a tabbed interface.
Unfortunately thanks given cannot be removed :(
We'll be adding options for the collapse display in the future :)
If by graphic you mean the button images then yeah :)
PS: We have a pre-sales forum here: Pre-Sales Questions - this isn't exactly a "Problem with www.dragonbyte-tech.com" ;)
Hmm. I want it to be overall. Like the 5 leaders of thanks recieved. How to fix that? (Sorry if you already answered that question, I´m tierd..)
It cant be removed? Not with some programming? Some code to remove? And I can´t remove the collapse with some code either?
I don´t know if it is an image, or what it is. But as you see here: Test . I want it to look the same as, "inlägg" & "regg.datum". But if you cant remove the collapse, than this question doesent matter...
Thanks for greate answer!
There is no way to "fix" that - it's not broken :) It was designed like it is :)
I'll see if I can get it added to v3 of APTL during its Beta period :)
I'll see about making that optional too :)
That is something you will have to ask your skin developer, I'm not familiar with your skin so I cannot tell you, sorry :(
Okey. I will have to wait than. When do you schedule to be done? Can you add an option for having "top 5 thanked members" in the widget?
Best regards
There's no set schedule for when the features will be implemented.
If you notice the mods go Gold without the block change implemented, please post it as a Feature Request in the appropriate forum :)
