DBSEO 1.0.0 beta 8
Just installed DBSEO lastnight to replace VBSEO and I've run into a complicate migration issue.
My forum layout has 4 main categories (forum acting as category) and within each category are child forums.
The structure is as such
FlashFXP > News
FlashFXP > General Discussion
Donationware > Software
with VBSEO this structure was mapped as
http://www.flashfxp.com/forum/flashfxp/news/
http://www.flashfxp.com/forum/flashfxp/general-discussion/
http://www.flashfxp.com/forum/donationware/software/
Now with DBSEO (after importing from VBSEO) the structure has changed to the follow
http://www.flashfxp.com/forum/news/
http://www.flashfxp.com/forum/general-discussion/
http://www.flashfxp.com/forum/software/
What can I do to make DBSEO handle a structured layout where categories and forums are nested?
As-is this leads to a rather complicated issue with handling the following situation
FlashFXP > Release Archive > FlashFXP 3.0 Release Candidate > Bug reports
http://www.flashfxp.com/forum/bug-reports/
ioFTPD > ioFTPD > ioFTPD beta > Bug reports
I was expecting DBSEO to be a drop in replacement for VBSEO but at the moment this does not appear to be the case, at least for my specific situation.
What's the value of the "Forum Path" and "Forum URLs" settings in the URL Rewrite Settings?
Update: Nevermind, I see the issue. I will notify you as soon as a hotfix is available.
Update 2: Multiple files have changed in order to correct this issue, I would recommend re-downloading the product and re-uploading all files.
Thank you for your amazing fast and prompt fix however I am seeing a slight problem.
I re-downloaded 1.0.0b8 and replaced all of the files on the server (and cleared all caches, etc)
There seems to be a slight problem with all forum urls showing as
http://www.flashfxp.com/forum/a/
or
http://www.flashfxp.com/forum/a/a/
The new build is live on my forum now if you want to take a look at it.
Unfortunately I am not able to give you direct access to this server.
"[forum_path]" = [forum_title]
"Forum URLs" = [forum_path]/
I have attempted to determine the problem on my own since I am unable to allow you remote access and I have come up with a crude hack to solve the problem that might give you some insight on whats going on.
I have included the details below as hidden text, since I wasn't sure the best way to share it.
[HIDE]
File: /forum/dbtech/dbseo/includes/library/forum.php
public static function createUrl($data = array(), $format = NULL)
// Grab our forum cache
$forumcache = DBSEO::$db->fetchForumCache();
the problem is that $forumcache doesn't contain the correct information for "seopath" however if we call the function with $force set to true it forces the cached value to be updated and this updates "seopath" to the correct value and thus the line becomes
$forumcache = DBSEO::$db->fetchForumCache(true);
Not sure if maybe the forumcache is being created before enough information is available to create the correct seopath or if maybe another function needs to be called to force the seopath to update.
I noticed that the DBSEO::filterText() function returns "a" and thus never returning "", at some point FilterText() must be passed some invalid information that results in "a" being returned, perhaps the text being passed is an empty string and that causes this whole mess.
[/HIDE]
Have you tried clicking the Clear System Cache link in the DBSEO CP?
If that doesn't work, are you able to set up a staging server and reproduce it there?
Yes.
I have some additional information for you.
(after undoing my fix)
If I view a post or thread directly after clearing the system cache then I can reproduce it every time.
i.e. http://www.flashfxp.com/forum/showthread.php?p=83196#post83196
Now if I clear the system cache again and then immediately load the main forum the problem doesn't seem to occur.
I did some php debug stack traces and came to the following
viewing a thread performs the flow logic
[HIDE]
DBSEO_Rewrite_Thread::createUrl()
DBSEO_Rewrite_Forum::createUrl();
My guess is that the second call to DBSEO::$db->fetchForumCache(); returns the wrong info unless $force is true since the cache isn't completely built at this point, my hack resulted in $force set to true side stepped the problem.
my guess is that the forumcache shouldn't be used unless its fully initialized and in this case its not when the second fetchForumCache() is called.
[/HIDE]
Can you try re-downloading and re-uploading all files, then clear the cache again?
I made a few other changes that may have affected this issue.
I am afraid that this update does not resolve the problem.
Your code changes don't appear take into consideration that the forumcache contains an invalid seopath
because your FilterText() replaces an empty string with "a" we have to take that into consideration when seopath is set to say "a" or "a/a"
if the $forumcache is initialized and seopath = "a", "a/a", etc then the cache needs to be updated instead of the cached value being returned, once the cache is set it doesn't appear to ever update the seopath with the correct values without being forced to do.
The "a" is a fall-back, and it's not actually relevant to the core issue at all. Without access to a staging server or at least write access to the DBSEO files for your live server, I have unfortunately no way of replicating this issue and thus no way of assisting you further.
Please investigate whether it is possible to grant write access to a specific folder (the "dbtech/dbseo" folder and all files within it) on your server setup so that you can grant me the access I require to look into this issue and fix it.
Update: I've been able to replicate this issue locally, I will post back when I have more information or a hotfix is available.
Update 2: This should now be fixed :)
If you re-download the product, re-upload the files and then Clear System Cache within the DBSEO AdminCP, the URLs should display correctly.
