Tabs are not correctly located in advanced editor mode
sz1
Hi there,
The tabs show up correctly in the direct answering mode of the editor (screen 1). But if you go into the advanced mode they´re in the upper right corner of the editor (screen 2), although they´re supposed to be below the editor like in the direct answering mode.
Hope you can help me with this. I don´t know what went wrong ;(
Regards
SZ
Per the readme file (which was hopefully part of the download?), you need to turn off the smilies on the side of the editor. In ACP > Settings > Message Interface Options, set the number of smilies to be shown to 0 and that will correct the issue.
Brad via Tapatalk
Oh my god sorry for that! How embarrassing
Works fine now! I didn´t read the readme carefully enough I guess...
Another question: Is it possible to turn of the custom BBcodes in the CKEditor? If I set up a tab with BBcodes they´re nonetheless superfluously in the editors BBcode-bar too.
Regards
SZ
Regards
SZ
Not a problem. I was thinking that perhaps I forgot to include the ReadMe in the package. As far as turning off the custom BBCodes in CKEditor, it would most likely need to be a file edit. I'll see what I can find out and let you know. Thanks!
Legacy vBEditorTabs
