janslu
I've installed beta7 today, and found few issues with sitemaps already:
1. Manual sitemap generation in dbseocp links to dbseocp/dbseo.php?do=buildsitemap instead of index.php?... any idea why? I'm using rewrite settings from the readme file.
2. lastmod for forums is set to 1970 in the xml file - I would expect it would the same as the last update for any thread inside
I'm unable to replicate this issue. Can you try clearing your .htaccess file so only the DBSEO rules remain? It's possible you have a conflict somewhere.
It uses the "lastpost" column in the forum table, which will always be 0 for sections. You'll notice that forums with actual posts in them have a proper lastmod.
I'll take a second look tomorrow, but for now I did clear my .htaccess and it didn't help:
RewriteEngine On
RewriteCond %{REQUEST_URI} !(apa/|dbseocp/|mpa/|cron|mobiquo|forumrunner|api\.php)
RewriteCond %{REQUEST_FILENAME} !/(apa|dbseocp|mpa|clientscript|cpstyles|images)/
You are right!
If you can't find a solution to the issue, feel free to PM me with an AdminCP and FTP account and I'll take a look :)
