Steris56
how do i get my moods to look like they are here right now the mood and status appear above my avatar i want them to look like you guys have
thanks in advance
It's automatic :)
Just visit a thread with USM installed, then go to AdminCP -> DBTech - Postbit Tabs -> Manage Views
You should find it there.
It's automatic :)
forgive me but i cant find such a thread that does step by step can you possibly give me a link thanks
Hm, apparently USM doesn't support Postbit Tabs after all.
I have no idea how it got added as a View here on DBTech then :/
A future update of USM will add that support though :)
lol i thought i was going bonkers ...
let me ask you this what code did you change to get the results here to lower it to below avatar to me above the avatar looks terrible is why i asked the question if nothing can be done at this time i will wait for a new release thanks for the replies Fillip H.
Go to vborg and look at thread about USM mod, Ozzy explained it there, you need to create plugin, and you can place it wherever you want in postbit. I also explained there how I did this (I created new template hook and changed hook that mod uses to mine).
i have read it there but is a little confusing to me..i would need a better explained how to
you said --You need to edit file: /dbtech/status/hooks/postbit_display_complete.php
now this is on server to me db should make the changes so we dont have to or at least give an option to either have it above or below the avatar
i did it ozzys way created the plugin but i am comng up short there too i bet i am missing where to change the code for the additional steps
thanks alan
If you do as ozzy suggests, after you created plugin, you have two variables, or text, whatever you want to call it and you place them in postbit, wherever you want.
If you find this to difficult, you'll need to find someone to do this for you (you need to trust this person as this person needs to have admin rights on your forum, even temporarily), or just leave it there till you'll know more how to edit templates, files etc.
if you better explained this in your how to i dont think i would be confused about what steps to do next and where to go to add the variable
Legacy User Status & Moods
