I suggest doing the following:
- In your Admincp find Maintenance -> Diagnostics -> Suspect File Versions and hit submit.
If there are any files that don't match up, reupload them.
- Next, create a new style by doing the following:
Styles & Templates -> Style Manager ->[Add New Style]
- Now finally edit your /includes/config.php file
Find
<?php
Add below
Now, once you have done those steps try doing it again, using the new style you made.
If you still get an error I suggest opening a ticket at vBulletin.com.
If it works, try removing the line you added to your config file, if you get the error it means its a modification causing the error, if you use another style, it means the style is the problem and so on.
Hope this helps
