vitrag24
2 Modification request & 3rd better design/layout for forum
Vbulletin version 4.2.1 and support for future version update/bug support needed.
Reply with your price for each work separately and combined if any discount.
1.Question below nav bar mod
2. Vb Quiz/ Online mock test mod
3. better design/layout for forum like on ipodtouchfans.com, digitalpoint.com, vbulletin.org etc.
Checkout following file for more details of requested modifications.
http://www.mediafire.com/?lza2rs648uzkq4v
1) Our rate is $2500 per week (minimum of 1 week payment required). Assuming our understanding of the request is correct, it would probably be a little under 1 weeks work and cost the minimum fee of $2500
2) vBQuiz will be available to purchase in the next week or two
3) This isn't a service we offer
1. 2500USD. Thanks but i cant pay even 1/10th of it for such simple mod..max 20-40USD depends on work..Your products better than this mod and even such mod for quotes available for less than 25USD, i hope u added "00" in mistake. :confused:
You can even chk, that mod was inbuilt in "zoints" forums for free in earlier versions..
2. PLz consider features i requested in vb quiz before u release it & if possible, release it by 10th...visit elsevier-examzone.com, register for 30days free and try theirquiz..they have all needed features..i want similar one..thx..
3. ok..
3. ok..
1)The 00 was not a mistake :) To do a custom (or requested) modification means pulling a coder from their usual schedule. This has to be financially viable both for the coder and for the company. $2500 per week is the figure that satisfies those criteria. We are professionals who do high quality work for some of the largest forum communities on the internet, work like that does not come cheap. :)
2) The featurelist for vBQuiz is already finalised. The product is in the final stages of testing and minor tweaking. As always we welcome suggestions from customers who buy the product on ways to improve it, and we strive to add those features to future versions.
Cosmic
Cosmic
1. thx but i will pay you 2500USD if you get single customer paying 2500USD for mod i requested . anyways, i'll find another coder for that..thx..
2. plz consider features i requested if possible..i would really want to buy..
