Can import the product. Freezes after this
Lite version installs just fine.
I check my logs and found this error...
PHP Fatal error: Call to undefined function unserialie() in REMOVED/dbtech/vbshout/install/450.php on line 94
Looks like a file issue in the install folder.
I can't seem to get it to install. Any Ideas since you marked it as "Not a Bug"? I thought unserialie() was a typo ans suppose to be unserialize(), but that is not the case.
I purchased this product and can't get it installed. How long does it take to get a support person to respond with something? EX: we are looking into it and will get back to you soon.
I'm getting a little frustrated here. The lite version on VB.org installs and works just fine, but I buy the PRO version and the product import freezes.
Come on now!
Updating Version Number To: 4.0.0
Created Table: dbtech_vbshout_ignorelist
Created Table: dbtech_vbshout_log
Created Table: dbtech_vbshout_shout
Altered Table: administrator
Altered Table: forum
Altered Table: user
Altered Table: usergroup
Populated Table: datastore
Populated Table: dbtech_vbshout_shout
Updating Version Number To: 4.5.0
Created Table: dbtech_vbshout_command
Created Table: dbtech_vbshout_deeplog
Altered Table: user
Created Table: dbtech_vbshout_chatroom
Created Table: dbtech_vbshout_chatroommember
Created Table: dbtech_vbshout_instance
Altered Table: dbtech_vbshout_shout
Come on now!
