I didn't know where to post my questions so I am posting in the off-topic section.
I am running vBExperience 4.0.3 on my VBulletin forum 4.0.6. I am thinking of starting a paying to post kind of contest on my forum that uses vBExperience.
But I am having a few problems and wish to clarify/troubleshoot some problems:
1. When a member's posts are deleted (soft-deleted to be precise), their vBExperience points don't seem to deduct. The number of points stays the same. Any help/troubleshooting method?
2. Is there a way to reset only a selected few members' vBExperience points?
3. The "Give Away Points" feature does give away points to a certain member. But those points are not deducted from the sender and not added in the receiver's vBExperience points. Any method to fix this?
4. How can I enable my moderators/staff to use the custom method and manually add/deduct points from members' points?
5. In the "Give Away Points" feature, is there a way a member can also enter an optional message to the person he is sending to?
6. Is there a way to limit post/new thread points from being given in certain sections of the forum?
Also, I have been trying to install a Facebook Connect mod similar to the one that is installed on DragonByte-Tech. But whenever I try to install it on my forum, it gives me errors. Does anyone know of a working, error-free Facebook Connect mod that I may install on my VBulletin 4.0.6 forum? Is there a link to such a mod that I may have?
Furthermore, is there a Thanks mod for vBulletin 4.0.6 that has a feature in a user's cpanel to see who thanked which post? I have a Thanks mod installed but the members can't see who thanked which one of their posts. And is there a way that the Thanks mod can be compatible with vBExperience so that thanking and receiving thanks for a post increases the vBExperience points?
Looking forward to a reply.
Thank you,
Angie
Thank you,
Angie
