I'm a bit confused as to what you're asking?
I'll test this locally as soon as I have time :)
What I am saying is that the archive adverts are not showing, I am not sure if that is a vbulletin advertising issue or your modification... because they run in parallel.
Regards
Mick
The issue is that the Archive loads differently from the front-end, so Forum Ads doesn't run there. I'll fix this for the next version :)
I have uploaded all the files, and imported the new XML.
Also cleared all caches and restarted PHP after uploading the files.
I Still cannot get them to show, is there something that I need to do in order to see them?
Regards
Mick
Can you confirm the "Global Initialisation - Archive" plugin exists on your forum?
Is that supposed to be in the dbtech forum ads plugin list?
If yes then I do not have that plugin?
Thank you
Sent from my iPhone using Tapatalk
For some reason the XML file didn't update correctly. I've fixed the product files for v1.0.2 Patch Level 1 now :)
Legacy DragonByte Forum Ads
