Kirk Voclain
I want to make a few adjustment:
1. How do I make the banner that is under the NAV BAR "CENTERED" on the page?
2. My banner is not showing up under Header2.....I can get it to work on the NAV BAR but not header2....have any suggestions? I do have some various skins on my site...but the standard default VB skin is one of them and for now I'm only testing this banner thing on that skin and then will adjust if needed on the other skins. My banner is 600x60 pixels....is that just too big to show up in header2? Suggestions????
3. Do you have any documentation for the mod? Some things are confusing? I read in another post about someone haveing problems getting banners to show up and they were told that under EDIT BANNER and "Remaining" that it was set to zero and this was why there banner was not showing up. Mine was the same way and were not showing up till I set this to 1. But in the description on that it says this: (Remaining
How many of the above tracking type this ad should run for. Note: Does not apply to the "Time" tracking type.) ALL of my banners are tracked by DATE or TIME....so.....thus all my banners Impressions and Clicks mean nothing.....I sell them by the date...usually 1 year in advanced. So they do not expire for 1 year. I do NOTHING with Impressions and Clicks. So....seems to me that this means this for an expiry date or "TIME" should be set to zero? What does changed this to 1 or what ever do and mean? I'm so confused about this....if it's set to zero...the ad does not show up?????
HELP????
Kirk Voclain
HELP????
Kirk Voclain
