At a guess, the importer pulls your details from the
vbseo/resources/xml/config.xml file
So if you have a backup of that file you might be able to just upload that file back to your server and then use the importer ???
I am not sure just trying to help
But you should of not removed VBSEO until you knew you was all good.
I personally MADE a backup of everything including my database, vbseo files, then started to PORT the mod over.
This is how I did it.
1) Backup Mysql, and your VBSEO folders
2) Turn off vbseo from the plugins page (DISABLE IT)
3) Install DBSEO via the instructions.
4) Once Installed goto the DBSEO Panel
5) Bottom Options you will see import VBSEO (Import)
6) Click it
7) Now go into the URLS section
s of the DBSEO control panel and double check all your links are correct
8) Double check this by searching google for a thread that you know exists and click that thread via google it should then take you to the same page
9) if all good remove the VBSEO Files.
10)
DO NOT UNINSTALL if you have the VBSEO Likes System working, you will need to either find another mod and if you unistall you could lose all the LIKES!!!
I personally have not uninstalled VBSEO, I have it SWITCHED OFF... at this time I need to work out something for the likes
But it worked fine for me and I have over 2 million posts so the importer works great!
Mick
