Question System test blank result
This could be related to the problem your server is having of not being able to load your forum within a respectable amount of time.
Do you ever see the "spinning loading bar" before it shows you what you have screenshotted?
PS: Please use the full version number when filling out the Product Version field :)
Never see the "spinning loading bar" before it shows the result :)
Ok.
Hmm, is your memcache config setup correctly and enabled in vBulletin config.php?
