Robert9
I have chossen either /droot/sitemap and /droot/forum/sitemap, both set to the user this domain belongs to and both set to 777,
but the script wont write my sitemap-files.
Any idea what could be wrong?
Please try creating a folder called store_sitemap in the folder where your forum files reside, CHMOD it to 0777 and set the sitemap path to ./store_sitemap and see if that works for you.
Path issues would indeed prevent the sitemap from building correctly.
Unfortunately not.
I tried
doc-root/store_sitemap
doc-root/forum/store_sitemap
and
./store_sitemap
like you said.
I have 777 and the right user set.
I maybe should watch the code now to see where the script tries to save.
This is unfortunatley not possible.
But tell me please, it is possible that the failure comes from session-management and not from rights to write?
Is it possible that another addon will disturb the script?
Maybe a changed table?
It seems there is the following fault:
in removesession.php find
doremovesession
there
$vbulletin->db->query("DELETE FROM " . TABLE_PREFIX . "adminutil WHERE title = 'sitemapsession'");
but the data in adminutils is:
dbtech_dbseo_sitemapsession
Either we need sitemapsession instead of dbtech_dbseo_sitemapsession
or we have to change
to
$vbulletin->db->query("DELETE FROM " . TABLE_PREFIX . "adminutil WHERE title = 'dbtech_dbseo_sitemapsession'");
Please tell me what will fix it.
I hope you will find time to find this error in your script and solve it till the next update.
The problem was/is that the value dbtech_dbseo_sitemapsession is written in table adminutils, but removesession.php asks for sitemapsession and not for dbtech_dbseo_sitemapsession.
