robtbs
Hide and Sell Content with vBCredits
works with this?
also
error:
The point field has been entered but no data exists in this field name.
credits 0
any idea?, i try posting, but i dont get credits
Darkwaltz4 will reply as soon as he gets time to =). Unfortunatly time is limited and pro customers are given priority support for obvious reasons, but he will get to you.
Meantime to help could you post the contents of your post event and actions, and also let us know what version of vBCredits and vBulletin you are running? Thanks.
i want to buy the pro version
but the lite version is not working
so ii guess the pro will not work either
:S
im using vb4 and the last version of vbcredits
thanks
Could you post the contents of your post events and post actions sections of the vBCredits ACP? (also which version of vb4 are you running? e.g 4.0.x)
actions
Thread [All Usergroups] [All Forums] amount 5 , active
also post replay is 2
and for the other
i have post and threads active, 2 and 5 points
I have been looking at several people today who have the same issue, and yours sounds similar. Can you PM me an admin login and ftp access? I will take a closer look for you.
Also, the ability to charge for content has been implemented in the next version :) We should be demoing it on dbtech in less than a week. If you used the old version... its been implemented with zero file edits and zero template edits, and is not buggy like it used to be :D I always felt bad about the old version.
Legacy vBCredits II Deluxe
