doctorsexy
Trying to intergrating shout into arcade template and i am getting this error..
Warning: Invalid argument supplied for foreach() in [path]/includes/functions.php on line 3555
The following error occurred when attempting to evaluate this template:
%1$s
This is likely caused by a malformed conditional statement. It is highly recommended that you fix this error before continuing, but you may continue as-is if you wish.
Is there any fix for this ...thanks
%1$s
That is a known issue, and lies within the templates for the arcade, not a shout problem.
Unfortunately it seems vb4.1.5 and above will not parse the template syntax it is currently using.
Darkwaltz4 was looking into a way to make it work.
