hello
i want to ask about how to disable point / credit transfer, so my user cant transfer to another user
and how yo disable decimal, i need some fix point, exp: post = 5 points, thread = 5 points
if user made some post and thread, so their points will be 10 points, now 10,12 or 10,23
thanks
Both of these can be handled at the Multiple Currency Integration link in your admincp under the vbcredits menu.
The Rounding setting controls how many decimals to show (use 0 to hide them).
If you show advanced options, you can set to No the Transfer To and Transfer From settings as well to prevent it from being transferable.
The Rounding setting already 0, but it still showing decimal
check this
and another question, why i just started vBCredits, and one of my member get more than 1000 points
i check his log, there are no transaction on that, and his not online when he got that points, this bug or not ?
thx
Do you have any other addons installed that are connected to your vbcredits points?
I can't see that link without having an account to login. Does it show the extra decimals everywhere or just on that page?
Legacy vBCredits II Deluxe
