MudRacing
Fatal error: Class 'ZipArchive' not found in /web/htdocs/www.spqrclan.com/home/web/dbtech/downloads_pro/modules/downloadModule.php on line 35
On the second issue:
Code:Fatal error: Class 'ZipArchive' not found in /web/htdocs/www.spqrclan.com/home/web/dbtech/downloads_pro/modules/downloadModule.php on line 3
I think you will need to enable the Zip extension in your php.ini. You can ask your host to do it![]()
Directive Local Value Master Value
zlib.output_compression On On
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
