Website
http://www.captivereefs.com/
Product version
1.2.6
Forum version
vBulletin 4.2.x
#3
Can it be installed now with the files available for install? Or wait?
Also another nice option would be to turn off avatars if desired or turn off avatars for guests only.
Belazor
Staff member
Owner
Developer
Did you check the image path and see if it uses the /thumbs/ or whatever directory name instead?
Belazor
Staff member
Owner
Developer
Ah, I see the issue. I've apparently queued up a "Patch Level 1" release that I never actually got around to releasing.
I'll release this update on Monday :)
Belazor
Staff member
Owner
Developer
I've checked the files on your server and you are still on v1.2.6.
I have uploaded the v1.2.6 PL1 files to your server, and the thumbnail now displays correctly :)
#13
Strange I re-downloaded from vb.org. And uploaded in to my site.
Thanks for your help. I will be converting most of the lite products I am using into pro-versions soon. You guys are the best and am grateful for your support.
#14
Well... after checking this, I see that the livewall displays with thumbnails, but I was hoping that the forum block would use the thumbs (more so even than the wall itself). Perhaps I can use the same variable to convert the forumblock in the template?
Forum Live Feed & User Wall
